2001 warrior upgrades?
Old Jul 9, 2001 | 02:41 AM
dannyd38's Avatar
looking to buy front tires and what do i need to do to get better throttle response??
thanks
Old Jul 9, 2001 | 02:47 AM
Blaster96's Avatar
More responce come from a Pro Meg white brothers scilencer. Get some bnadits for the front. Also a hi-comp wiseco piston.
Old Jul 9, 2001 | 03:07 PM
TitanRacing25's Avatar
get u a set of magnum handlebars from dirtdeals.com they will make your warrior respond 10 times better!LOL
Old Jul 10, 2001 | 01:48 AM
ridnwarrior's Avatar
Since you're running a set of Holeshots in the rear I would get a set of Holeshots for the front. About better throttle response, try running the quad without the torque stuffer. See what happens. Did you rejet the carb after the mods? Maybe a K&N jet kit is needed. Otherwise I would say your next move is a mild cam for the quad. Depending on the money you want to spend you could go with a wild cam but then you need to do valve springs. Check out Powroll.com
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
