Warrior Engine Blaster Frame?
Old Aug 29, 2001 | 02:13 AM
Killntime's Avatar
A friend of mine just bent his frame on his 99 warrior. He can get a full blaster minus the engine for almost nothing. Is it possible to put the Warrior engine in the Blaster frame? What would it take to do it? If not if anyone knows about a warrior frame for cheap let me know.
Thanks
Killntime
Old Sep 1, 2001 | 02:28 AM
Killntime's Avatar
Any help is better than none...
Killntime
Old Sep 1, 2001 | 11:59 AM
Peltrax's Avatar
Well if any help is worth it,it loooks to me like there wood be enough room to fit it in as long as you welded new mounting braces and pipe ones too,,,,,,,
Old Sep 2, 2001 | 02:32 AM
Blaster96's Avatar
Just need a welder. New brackets, and the electronics from the warrior would need transferd and a spot for the blatery would need to be found. I would go for it.
Never heard of a cheap frame-
Old Sep 2, 2001 | 02:47 AM
bermbanger400's Avatar
killntime i dont know about where you are from ,but around here you can pick up warrior frames really cheap. my brother-in-law bought 1 for 200 bucks everything but the motor.he is going to do just the oppisite he is going to put his modified blaster motor on the warrior frame.
Old Sep 2, 2001 | 03:17 PM
Mr45auto's Avatar
Just watch ebay, see warrior frames every so often. Usually go pretty cheap.
Old Sep 5, 2001 | 01:39 AM
Killntime's Avatar
Thanks for the replies. Like I said I am doing the research for a friend. I told him to scrap it and upgrade... I guess cost is an issue. He can get the whole blaster minus the engine for 500$. I guess I will tell him to try it.
Thanks
Killntime
Old Sep 9, 2002 | 08:10 PM
RaceWarrior350's Avatar
www.eastcoastatv.com he can get a used frame for 500$ thats used but not bent or wrecked, somthing from a warrior with a blown motor. Peace
Ryan
88 Warrior
Red/White/Black
Pro Circuit T-4
K&N AirBox Removed- Custom tube kit
Redone Plastics
Dunlop Pro Brake pads
DG Alloy Nerfs
Fresh Rebuild On Motor
Duro Rears
99 Blaster
FMF Power Core 2 Silencer
Gold Series Fatty Pipe
Old Sep 9, 2002 | 09:53 PM
WarriorMadness's Avatar
You can get a warrior frame for less than $200 on Ebay. I sold one for $120. I wouldnt put that heavy motor in a blaster frame. If you make a good jump it will break in half. Besides the Warrior has better brakes and suspension. Just pickup a used frame and go from there.
bermbanger,, I asked about putting a TRI-Z engine on my warrior and everyone said that if I done that blaster would pass me. Said it wasnt worth the time.
My cousin put a Suzuki 125 quad engine on a blaster so I guess anything is possible.
Good Luck
Reactant
Mar 30, 2022 02:08 AM
Reactant
Jul 16, 2015 10:29 PM
joeyupton
Jul 14, 2015 11:51 AM
RedRancher
Jul 10, 2015 06:36 PM
bikedad3
Jul 2, 2015 02:15 AM
