any suggestions for removing a tight warrior axle nut
Old Feb 17, 2004 | 10:44 PM
loveMyYamahas's Avatar
Default any suggestions for removing a tight warrior axle nut
take a big pipe wrench and put it on the axle on the side with the RIGHT wheel, with the handle on the floor, so that when you try to break the bolt loose, the wheels wont spin, (they will spin even if in gear and brake on) now heat teh bolt up with a torch (map gas is hotter than propane, [img]i/expressions/face-icon-small-smile.gif[/img] now take your mama luke pipe wrench ("24) with the fence post (i had to use the same thing) and position it on the nut and with a buddy pushing down hard on the grab, break the **** loose. Dont take your tires off before you get the axle nut off, break the axle nut loose, then jack it up and remove wheels, hubs, etc. if you try doing it on stands, it'll be much harder and you risk knocking it off the stands..hope this helps
Old Feb 17, 2004 | 11:09 PM
kawasaki88man's Avatar
Use a 8 ft pipe lol Jp
Old Feb 17, 2004 | 11:31 PM
FISHER1648's Avatar
The inner and outer nuts will bind against each other to the point where they get stuck together. That's how they are supposed to stay tight.....try tightening the inner nut a tad, to break the lock,then loosen the outer.
Ooops - upon reading the post again I assumed both nuts were still on - right ? If the outer is already off, ignore me !
Reactant
Mar 30, 2022 02:08 AM
Reactant
Jul 16, 2015 10:29 PM
cSchwartz
Jul 12, 2015 07:42 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
Rider252
Jul 6, 2015 03:37 PM
