To all wolverine owners(top speed)
Old Sep 28, 2001 | 09:41 PM
DeerSlayar's Avatar
Have you checked your top speed for your Wolverine? According to my Etrex the top speeds for my quads are:
Stock 1999 Yamaha Wolverine 350 4x4: 46.4 mph
1986 Suzuki Quadsport 230 w/DG pipe: 49.0
1985 Honda ATC 200S: 46.1
The speed for the Wolverine seems way lower than exeryone elses, I think something must be wrong. I have drag raced a 1998 Honda 300 4x4 and can only beat it in a very long drag race by 1-2 mph. I am not sure if the 300 was stock since its front tires were popping up in 2nd gear, mine were only coming up in 1st. It's pretty embarrassing to get beatin a 100-150 yard drag race by a utility 4x4 when you are on a "sport" 4x4. Any suggestions on what could be wrong? My jetting may be a little lean since it gets hot easy. What about using the cheap gas? Any help would be appreciated.
Old Sep 29, 2001 | 01:33 AM
Blaster96's Avatar
The wolvy stock top speed is about 50mph. NEVER USE CHEAP GAS! low octane gas can cause pre-ignition (detination) and blow your piston to pieces. If you want a lot more power get a WB PM pipe. it will make all the differacne in the world.
Old Oct 9, 2001 | 07:21 PM
DeerSlayar's Avatar
I use it for hunting and don't want to make it too much louder than it already is. How loud is that pipe? How much? Is it a complete system or just a slip-on? Almost everyone i have talked too has said it should go 56-58 stock. In dirtwheels it jumped all over the Rancher in everything but "creature comforts" so I was expecting to easily beat even a slightly modified 300 4x4 since it was the predessessor to the Rancher. I will still take the Wolverine over a 300, it has a way better suspension, way better handling, better for trail riding, and looks way better. I do think the 300 would have the edge in deep mud or heavy towing, though.
Old Oct 9, 2001 | 11:57 PM
wyd's Avatar
wyd
I have a new 01 Wolverine and I checked with my GPS and had it to 45 and let off since it has only 50 mile on it. It was still pulling very hard and I can see 50 plus is really no problem at all. I think when I have it broken in well it will get to 55 pretty easily. My Sportsman 400 would do 50 and it is 200lbs heavier.
Old Oct 10, 2001 | 07:13 AM
macgiver's Avatar
i got clocked by radar at 60, on my 95 wolverine with stock tires. it has a wb pipe, k&n filter and jet. the needle is also raised up one noch, the motor is very loose, and isnt going to last much longer
Pehter
Oct 3, 2024 11:00 PM
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
ReconBayou
Sep 23, 2015 02:41 PM
