HOW IN THE STINKIN' WORLD DO YOU BLEED RAPTOR BRAKE LINES?
Old 10-22-2001, 11:43 PM
Bartman's Avatar
I just put some new Fastline steel braided brake lines on my Raptor and I can't seem to get any fluid to go into the lines! It's taking forever. Is there a trick to doing this? Please help. thanks
Old 10-23-2001, 12:19 AM
chasman's Avatar
No trick, it actually takes that long. Stinks, but is worth it in the end.
Old 10-23-2001, 01:03 AM
yambike's Avatar
Try tapping on the calipers with a screwdriver handle. Also tap on the brake lines and on the T connection on the brake lines as well. If you pump the brake lever while doing this you will see air bubbles rising out through the master cylinder. It saves a little time. Vacuum bleeding systems work good too.
Old 10-23-2001, 01:23 AM
Bartman's Avatar
Thanks guys, I saw the little bubbles, it just didnt'seem to be working very fast. I guess it will just take some time. I will try your suggestions. Thanks
Old 10-23-2001, 10:13 AM
leel2's Avatar
I had the same problem when I put new brakes on the rear of my son's 300ex. A buddy and I spent an hour or two trying to get the rear brakes bled, but couldn't get the master cylinder to build up any pressure, so hardly any fluid would come out. We ended up having to get a "vacuum" brake bleeder that connects to the bleed screw and sucks out the brake fluid via a pump lever. With this tool, everything came out OK.
Good luck,
Lorrin
Old 10-23-2001, 10:46 AM
IceMan11's Avatar
It takes frieking forever to bleed these brakes. Half the problem is you can't tell how much brake fluid in the rezivour <sp?> by looking through that little window in the front. Just keep taking the lid off and filling it up with brake fluid and it won't take as long. It still took me 45 mins to bleed it tho.
STLyamwar
07-25-2020 04:44 AM
SixSpeed5
8
08-02-2015 05:38 PM
black_thunder
07-22-2015 06:01 PM
Sandman2.0
07-21-2015 09:03 AM
Dirtbikemike1
07-11-2015 03:36 PM
Quick Reply: HOW IN THE STINKIN' WORLD DO YOU BLEED RAPTOR BRAKE LINES?
