Pro Design kill switch
Old Jan 7, 2000 | 06:55 PM
116's Avatar
116
I have a 96 Banshee. I am going to put a pro design kill switch on it. I was just wonering, does it wire into the key or does it wire into the manual kill switch?
96 Banshee 96 Warrior
Old Jan 7, 2000 | 07:01 PM
jblough's Avatar
I just installed one. I removed my stock kill switch though. It does wire into the kill switch wire. I took apart the wire harness to do it. The wire you need to connect to is black with small silver stripes on it. You also need to tie the other wire into the ground. That is the collection of all black wires. Hope this helps.
Jayson Blough '99 Banshee, '97 Warrior, '96 Blaster Yes I like Yamaha
Old Jan 11, 2000 | 06:35 PM
Fijit's Avatar
put one wire under, like stuff it in with one of the coil clips on the coil, put the other wire to ground, simple, effective, 5 minutes, done
fordfaithful21
Dec 7, 2015 05:52 PM
nick c
Sep 13, 2015 10:08 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
