wow miller welder !!!
Old Oct 27, 2001 | 06:52 AM
biggy's Avatar
well I know this is not related but Im so happy now !! I went to go buy a new mig welder,and when I was there I noticed they are giving a FREE spool gun away when you buy the 250 model ..so now I can do aluminum,steel,and stainless,man Im going to be building some cool stuff!!! needless to say I went there planning on spending $800 and I left there short $2,000!!! oh well ~NEW TOY~ he he
p.s the only bad part is now I need to stock three differant gasses
Old Oct 27, 2001 | 12:45 PM
lonestarbanshee's Avatar
3 different gases? I run mine off Argon. I also have a Miller 250. Remember, push instead of pull, and you will be laying the prettiest beads you've ever seen.
P.S.- Wire doesn't hold like stick.
Old Oct 27, 2001 | 03:14 PM
fourlix's Avatar
Free spool Gun? cool. I also have a Millermatic 250 with a spool gun, from Ram in Ca. I use CO2 for steel, Argon for Aluminum. I have used the helium tri-mix for stainless, but not with this rig.
The Millermatic is a good machine for MIG mild steel. But for professional results in anything exotic you need better. There is a new Pulse millermatic for aluminum that looks really good for the money. And the Maxstar TIG setup is the up and comer for ChromeMoly. I don't know what the hot setup for Stainless is these days but it may also be one of these new inverter type welders. The real deal used to require 3-phase, but the inverter power supply may get around that. The Millermatic 250 splatters a lot with stainless.
.....Funny, Ride Blue, Weld Blue. Yamaha and Miller run the same color.
Go Blue!!
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
hoopduerr
Jun 2, 2015 09:01 AM
fourlix
Sep 21, 2001 09:51 AM
