Want help for warrior modifications.
Old Jan 15, 2000 | 08:58 PM
jeff00's Avatar
if you got any suggestions on some mods i can do to my 99 warrior, i would apreciatie it. either post it on here or mail me at jeff38829@hotmail.com.
Jeff
99 warrior
Old Jan 16, 2000 | 12:42 PM
99_warrior_350's Avatar
Buy a pipe. White brothers or fmf are good pipes and will give you a little more power
Old Jan 16, 2000 | 02:33 PM
Johnnnn__H's Avatar
How about a torque stuffer??? I don't have a torque stuffer, but have been thinking about getting one, it is pretty cheap about 35, 40 bucks,I think. Anny one have one of these, and did it make a noticable differance?
Old Jan 17, 2000 | 04:25 PM
Blaster_2000's Avatar
I have a 96 Warrior and have been thinking about getting a white brothers E-series for it. Does anyone know if it would reduce reliability or engine life?
Thanks
Old Jan 17, 2000 | 05:07 PM
2000_Warrior_350's Avatar
I noticed a gain in bottom-end torque after installing a torque stuffer...can't say if it affected the mid to top-end though...really don't see a difference there. As far as an aftermarket pipe affecting reliabilty or engine life, I really don't think it will hurt anything, just make sure you check the plug to ensure the pipe hasn't caused your machine to run lean.
Old Jan 18, 2000 | 01:47 AM
Mr45auto's Avatar
Probably not the mod you were hoping for but the best go fast mod you can do isnt with the engine. I have seen the best results from installing a steering damper and Maxxis All-Track rear tires in the stock 22x11x9 size. These two things make such a huge difference that you wouldnt believe it. As far as motor mods opening up the airbox, a K&N filter and proper jetting is the best thing you can do. The stock pipe flows pretty well but a good performance pipe will pick up a bit more power. I have a torque stuffer and I'd reccomend it, the effect is noticeable.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
