Upside Down Front Shocks on Raptor
What flipping your shocks does is it lightens your "unsprung" weight by bolting the heavier body side to the frame, and the lighter shaft side to the suspesion. The shock itself will still react the same way, compression is still compression and rebound is still rebound. Unless you are a serious racer that has gone to every extreme to lighten your unspring weight, you won't notice any difference. Also I wouldn't recomend flipping any shocks that are not gas shocks, as they tend to begin leaking around the shaft seal much sooner than normal. I don't think the front Raptor shocks are gas charged.
JPBRaptor
JPBRaptor
EDD your point is exactly correct. The action is too fast.
I put my shock on a shock dyno in both configurations and they were completely different.
Basically upside down they lost almost all the compression damping and the rebound damping had a huge delay. I think they start sucking air when they are upside down.
I will try to post the shock dyno data but I don't have a website. I can scan the data and send it to somebody if they want to post it. It is really interesting.
My recommendation is not to run them upside down.
i hit a little 15 foot double on my raptor with my shocks flipped, I wouldnt advise anyone to flip them, I'm lucky my frame didnt take a dump on me, or a shock bust, I got lucky, cuz as soon as my tires thought about hitting the ground they were bottomed out. and it wheelied when it sprung back up and almost flipped back.
