rounded shifter shaft
Old Jan 22, 2002 | 11:59 AM
epithelium's Avatar
I just bought a project 225 three wheeler for 100.00 problem is the shifter shaft is rounded I dont wan't to take apart the motor to replace the shaft is the another way i can rig this as not to spend alot of money. Thanks
Old Jan 22, 2002 | 12:03 PM
MNWildFan's Avatar
YOu could put a shifter on it, drill through the shifter and shaft, and put in a cotter pin or something. It wouldnt be as strong but it would work. Also you could tack weld it on there, just weld in a spot where you could grind the weld and remove it if necessary. Have fun
Old Jan 22, 2002 | 01:48 PM
epithelium's Avatar
will a weld hold isn't the shifter aluminum or pig metal.
Old Jan 22, 2002 | 03:03 PM
MNWildFan's Avatar
Good question, you could fab up a new shifter but that might take some work. If you weld it just make sure to do it in a spot where you can get at it with a grinder so you can remove the shifter if you ever needed to.
Old Jan 22, 2002 | 05:50 PM
250rampage's Avatar
I've had luck on a kickstarter shaft (same style teeth) by straightening out what was left of the teeth with a dremel. Since you might end up welding it anyway, you have nothing to lose.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
ReconBayou
Oct 16, 2019 02:24 AM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
