Prairie 650 vs. Grizz 660
660, all the way. The 650 is spotier with it's solid real axel and single suspension. But if you want comfort and in it for the long haul, that you better get the grizz. The IRS, soaks up all those unweanted bumps and gives you more ground clearence. I personaly don't liek the diff. lock on the 650. What if you wnat to use that other hand for something else? I am definatly a yamaha fan.
AtomicAustin~
It depends on the kind of riding you plan on doing. If you are into rough, technicle, off camber 4X4 riding, the Grizz will treat you better, and an IRS quad will go places that a solid axle wont. I'm not taking anything away from the Kawi, as by all rights it's a smoker. But the Grizz has IRS, prairie doesn't, Grizz has better ground clearance, and more suspension travel. If you ride mostly flat stuff and like to go fast, the Kawi's solid axle rear end and engine would not dissapoint you. ('Course I'd still pick the Grizz over the Kawi in that situation, but that's personal choice)
SilverBear
SilverBear
thats a question thats been pummelled around a lot. I think the best one is whichever you like the best really. They are so evenly matched and each has a very marginal advantage over the other is some areas, but they are really close. I liked the Grizzly so I got it, but I also found a lot about the Prairie that I thought was better than the Griz.
I got the Grizz because of the IRS. I wanted that. If I didn't, I probably would have got the Prairie on account of the good rear brake and the more steel and aluminum construction. Its a preference issue in all aspects, and I can't sit here and say that one is better than the other one. Its like comparing a Quarterback and a Defensive Lineman to say which is a better football player.
92LT~
I'm not taking anything away from the 650 Prairie. By all rights, it's an incredible quad, my only point is that IRS will outperform a solid axle when it comes to smooth riding over rough roads, or rock climbing and anthing that requires suspension articulation to keep all four tires planted on the floor.
Personally, I'd love to have a chance to ride a Prairie 650 and feel the power of that V-Twin.
SilverBear
SilverBear
