Toe in problem with 660 Grizz....
Old Feb 8, 2002 | 02:27 AM
coolinthewoods's Avatar
my friends Grizzly has 28-10.5-12 Outlaws up front with a lift kit and we notice it is toed in a lot. Is that the bigger tires adding to the factors allready toe in look or what?
Old Feb 9, 2002 | 02:36 AM
SilverBear's Avatar
Coolinthewoods~
I kept waiting to see if a techy here would answer, but according to the service manuel the toe-in is supposed to be 0-.39in. It appears to me the way that it is measured then yes, taller tires are going to change your toe in. Perhaps if Knowsalot is lurking around here he can verify that or debunk it. In the manuel you have your wheels straight, mark the very center of both front tires and measure the distance between the centers, rotate your tires 180 degrees and measure that distance again. Then take the distance between the center of your tires from the bottom measurement and subtract the distance on the top measurement which will give you your toe in. It just seems to me, if the toe in is correct on stockers, then oversized could possibly put you outside the paremeters set by Yamaha.
SilverBear
Old Feb 9, 2002 | 02:45 AM
buttfungus's Avatar
Or, you could order one of these and set it yourself! I odered one their about $50 bucks and very easy to use. Just let them know which quad you have and they will custom make it to fit your quad.
Toe Guage.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
