350 Big Bear Carb Question
Old Feb 11, 2002 | 04:29 PM
BigBlack's Avatar
Anyone know a aftermarket low end replacement carb for this machine. I just need to get an inexpensive stock replacement. Also do you know if a Stock Warrier carb will work.
Please respond
Old Feb 11, 2002 | 08:20 PM
KNOWSALOT's Avatar
The Facility
You already have the inexpensive [Mikuni] carburetor on your machine.
When Yamaha and Suzuki wake up and go to the Keihin like Honda and Kawasaki has, it will take alot of frustration out of carburetor maintenance and tuning.
You didn't say what year your BigBear is but if you have the '87-'96 model, your carburetor is a 34mm. The Warrior has a 36mm. It will interchange with yours with no modifications neccesary.
Also remeber that if you go with a larger carburetor [such as the Warrior] you will loose low end power and increase top end power.
KNOWSALOT
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
buckshit
Sep 24, 2015 08:49 PM
robj
Jun 15, 2015 08:45 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
