Banshee Transmission Problem -- HELP!
Old Feb 16, 2002 | 05:07 PM
lonestarbanshee's Avatar
I have gotten quite a few other opinions, and they all seem to think that the shifter star is worn out. Everyone I have talked to said that this is a common problem on Banshee's, and that it causes the problems that I have described. The part is $16.27 from Ronnies, and a gasket is really cheap. What do you think? Could this be the problem? The maintnence guy at my shop said that he thought that might be the problem, but he wasn't sure. I guess I should take the clutches out, and see. But before I do, I'd like to get an idea of what the problem is. Thanks guys, keep the info. coming.
Old Feb 17, 2002 | 08:53 PM
leffler12's Avatar
Just a thought but we had the same thing happen to my banshee so we split the cases inspected every thing inside replaced the shift shaft and still nothing so we did some more investigating and it turned out to be in the adjustment on the end of the shifting star its real touchy
Old Feb 17, 2002 | 09:18 PM
b370's Avatar
Lonestar:
What I was saying is that its a possibilty that a shaft/gear could be bad. I would always start out w/ the easiest repair and work from there. Rule out the obvious first.
Mp350
Old Feb 17, 2002 | 10:52 PM
b370, thanks for your information. I know exactly what you're talking about.
Cole Hadden
Jun 15, 2025 09:05 AM
Captjay
Jul 23, 2015 12:33 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
bikedad3
Jul 2, 2015 02:15 AM
