Sprocket Change on 99 Warrior
The thing on the bottom of the air box is a (the name slipped my mind) thing that allows you to see when the air filter needs changing by letting you see it. The best way to change the sproted and chain on a warrior is the replace only the front if you are lazy, or do the back as well. I would suggest the front first. Remove the Chain gaurd, plastic cover. Take off the old chain by removing the master link. Un-do the 2??? bolts on the front sproket. replace. Becarefull not to damage the seal that is behind the front sproket. Looksen you chain adjusters and install new chain. Tighten up, lube, and reinstall the chain gaurd.
Elkaholic
09-06-2015 02:44 PM
