Real world Raptor dyno test results
Old Mar 3, 2002 | 06:11 PM
  #51
SykoQuadRider's Avatar
Velociraptor. What cam do you have in your bike? I am getting the Mid Range. How much of differance between that and a full race?
Old Mar 3, 2002 | 06:29 PM
  #52
velocityraptor's Avatar
SYKO'
I HAVE A WEB MID TO HIGH, I'LL STOP BY THE SHOP THAT DID MY MACHINE THIS WEEK, AND SEE IF I CANT EMAIL YOU THE CUT SHEETS.( PENDING ON HOW BUSY I GET AT WORK THIS WEEK, BUT ILL GET THEM TO YOU.)DID YOU HAVE TO DO ANYTHING SPECIAL WITH YOUR HEAD GASKETS FOR THAT 13-1 ENGINE COMPRESSION?
Old Mar 3, 2002 | 07:04 PM
  #53
no i didnt have to do anything special with gaskets that know of. bike is in shop now getting all it done to it
Old Mar 5, 2002 | 12:03 PM
  #54
THEMOOSE's Avatar
velocity & syko, does your starter crank slower with the higher compression or does the decompression device compisate for it?
Old Mar 5, 2002 | 11:32 PM
  #55
[img]i/expressions/face-icon-small-cool.gif[/img]Moose:
I notice a little bit.Instead of opening up the choke half way when i turn it over, I have to open the choke 3/4 of the way.( this is only when the machine is cold, otherwise I just hit the start button abd it fires up with ease.) Only some one who rides a raptor on a daily basis might notice it.
Old Mar 6, 2002 | 09:27 PM
  #56
THEMOOSE's Avatar
At least I know when I put a high compression piston in my Lizzard the starter should live.
Thanks
Old Mar 7, 2002 | 01:23 AM
  #57
THEMOOSE's Avatar
hurycne, How did the Turbo test come out last weekend?
Old Mar 7, 2002 | 01:52 PM
  #58
ZRWHAT's Avatar
My motor turns over slower depending on where the motor is when I shut it down(Compression/Exhaust). I am running the 10.75:1, which should be in the 11-11.5:1 range with my 696/697 cam. I blew a head gasket on the first assembly(which was about two weeks ago). Turns out I got an original design Cometic head gasket. I've got the re-designed gasket now and used Threebond-1211 to seal it(Thanks Raptor720!). Never heard of using any type of sealant on a head gasket before, but it seems to be working. I won't know till I get it out for a couple hours of hard riding. I basically blew into the water jacket and pushed all of my coolant out the over flow.
COFatboy
May 2, 2020 12:06 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
black_thunder
Jul 22, 2015 06:01 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
