banshee brake problem!!!!! need help fast
Old Mar 2, 2002 | 11:24 PM
mudmanatv4x4's Avatar
my banshee has a front brake problem. when i pull the lever it doesnt do anything. the brakes do not work. i tried to bleed them and they still dont work. i think i bleeded them right. please give me any help you can give
thanks
Old Mar 2, 2002 | 11:38 PM
mud2myeyes's Avatar
What condition are your brake pads in? If they are worn to the metal, you will get little to no braking action.
When you bleed your brakes, make sure the fluid reservior is full, then pump the brake handle a couple of times and hold the handle down while loosening the bleed screw on the caliper. You should get fluid from the bleed screw when opened. Do not let loose of the brake lever until you have tightened the bleed screw back. Once you get to the point of solid fluid expulsion (no air), bleed the other caliper. If you are not getting fluid to the calipers, start the bleeding process at the line connection to the master cylinder in the same manner that you bleed the calipers and work your way down to splitter then the calipers. If you are not getting fluid explusion at the master cylinder, it probably needs a kit.
Old Mar 3, 2002 | 02:24 PM
i have the brakes off the mount because i needed new wheel bearings but i have new pads ready to be installed. i have bled the brakes many times and they seem to be fluid coming out. what other problems could be wrong?? the lever just touches the grip with no braking
thanks
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
