2000 Grizzly 600 Has No Spark
Hello all;
My 2000 Grizzly 600 won’t stay running. The problem appeared while running down a level dirt road at 50 Km/hr and then the ATV just quit running. I coasted to the roadside, stopped and restarted the ATV right away.
I then drove another 20 K when it once again quit running while going down a hill, I stopped once again to restart the ATV but she won’t stay running.
The engine will start after some effort and then idle for no more than 10 seconds and the moment you touch the throttle it stalls.
I got the ATV home and I checked for spark (GOOD SPARK) replaced the spark plug (OLD PLUG GOOD TAN COLOR), check the fuel line, remove the needle and jet checked the float and reassembled. At this time the ATV started right up and idled and rev under throttle for about 5 minutes. I let the ATV idle some more when it just quit, I restarted and it once again idled as normal for about 3 minutes before stalling. I have not been able to restart it since. It almost seems to starve for fuel or could this be an electrical problem? Like I said the ATV runs and idles normally and then just quits like when you use the kill switch. All comments or suggestions would be appreciated.
Thanks, Jeff Sutherland
[img]i/expressions/face-icon-small-frown.gif[/img]
<< Hello all;
[img]i/expressions/face-icon-small-frown.gif[/img] >>
Hello all;
Here’s an update on my Grizzly problem. I don’t have spark any more!! I have checked for the ignition pulse at the spark plug coil while cranking the engine and have even held the spark plug in my hand and guess what, no shock. I have verified the connection from the coil (orange wire) to the C.D.I. UNIT ASSY. Does anyone have an electrical schematic that you could e-mail me or know of anyway to test the C.D.I. UNIT? I also checked every connection on the ATV and they all look good, inside and out checked all fuses and reseated them. All comments are welcome.
Thanks, Jeff Sutherland.
It sounds like you have a bad pickup coil. It may be something else, but it can be tested. i have the manual and will look up the wiring colors so you can test the coil. I'll post it this evening when i get a few minutes. The bad news is if it is the pickup coil you'll have to buy the whole stator winding because, as usual, it's all made together. the good news is that it is fairly easy to change.
RticKwad
07-21-2015 03:00 PM
