Warrior idle help needed!
Old Apr 15, 2002 | 12:29 PM
Xteife's Avatar
My 87 Warrior has been sitting for a few years and recently I have found some time to put into getting it up and running again. After changing the oil, changing the plug, cleaning out the gas tank, slapping on a K&N, thoroughly soaking and scrubbing the carb, I got it started. BUT it immediately revs through the roof! I kill it b/c revving that high cannot be good for any motor, especially one that's been sitting.
I tried messing with the idle screw, but it didn't seem to change anything. The carb seems to be clean and everything's moving freely and not sticking. The throttle response seems good too and springs back quickly when jabbed.
Any ideas would be greatly appreciated. Thanks.
- G [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 15, 2002 | 08:08 PM
perrya's Avatar
The only thing i can think of off hand is your choke cable. maybe it needs to be adjusted or replaced.
Old Apr 16, 2002 | 12:51 PM
Xteife's Avatar
Choke cable? Mine doesn't have a choke cable. The choke is just a small black **** on the side of the carb with 3 positions. It seems to work smoothly and click into the appropriate slots...
Old Apr 16, 2002 | 06:58 PM
54warrior's Avatar
Being that you took the carb off to clean it, my guess would be that you might have messed something up in it when you tore it apart. I would take it back off of the quad and make sure everything INSIDE the carb is working properly as well. Good luck to ya.
Old Apr 16, 2002 | 07:36 PM
perrya's Avatar
i feel pretty stupid. What was i thinking???
my polaris had a problem with the idle and the choke cable wasn't adjusted right.
sorry for giving the wrong advice!!
njrider64
Jul 4, 2017 01:40 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
