Need Help...Fast! A day of riding is at stake.
Old 04-26-2002 | 12:01 AM
kybanshee's Avatar
On my Banshee I stripped out the nut that goes on the ball joint. I think it is called a castle nut. I plan on going riding tommorrow so I called the local dealership and they didnt have anything in stock. A friend recommended going to the local hardware store and get. Is this possible and if so what do I need to ask them for. Thanks a lot for the help.
Old 04-26-2002 | 02:39 AM
THEMOOSE's Avatar
Take the one off the other side & take it with you to match up the threads (don't forget their metric.). My Ace hardware store has castle nuts but I don't rember if they had metric ones. You can use a regular nut temporaraly if you loctite it (use blue not red or you may not get it off), the "castles" are for a pin to lock it into place. This will at least get you on the trail till you find the right nut.
Old 04-26-2002 | 02:41 AM
velocityraptor's Avatar
<< Take the one off the other side &amp; take it with you to match up the threads (don't forget their metric.). My Ace hardware store has castle nuts but I don't rember if they had metric ones. You can use a regular nut temporaraly if you loctite it (use blue not red or you may not get it off), the &quot;castles&quot; are for a pin to lock it into place. This will at least get you on the trail till you find the right nut. >>
Dave knows some $hit, dosent he! [img]i/expressions/face-icon-small-cool.gif[/img]
Old 04-26-2002 | 02:53 AM
THEMOOSE's Avatar
I can't afford to have someone else work on my $#!t so I had to learn to do it myself or walk! LMAO!!
Old 04-26-2002 | 10:18 AM
kybanshee's Avatar
Thanks for the help.
Old 04-26-2002 | 11:32 PM
warrior350megamax's Avatar
if you find the right nut, tighten as tight as it will be when you ride, mark where the hole is going through, then if you have a metal saw, you can make a temporary castle nut and use a cotter pin. by the way dont cut it too deep......SNAP, crash etc.
Nondem
02-22-2020 01:20 PM
HondaR24
07-16-2015 11:45 AM
honda71
07-12-2015 06:56 AM
Edgeslade
Where to Ride
07-10-2015 06:08 PM
honda71
07-08-2015 03:13 AM
