MAGURA CLUTCH ON A RAPTOR?
I guess I must have gotten a bad unit or something .... in any event - the I talked to the place I purchased it from and they'll will take the Magura back. I bought a manual clutch lever and perch - MSR - it has 3 lever pull settings - the easiest is suppose to be "325%" easier to pull - I'm going to hook it up and find out.
Thanks for the info. I haven't installed it yet, but this one has 3 slots for the cable end on the clutch lever itself - depending on which one you put the cable end into gives you 3 choices: wide open, normal and easier. Hopefully, this one will work - if it doesn't - well - pissing away 30 bones is easier to take than 200. BTW - not to change the subject of the thread but I noticed you have Axis shocks - how do you like them? I'm still running the stockers but thinking about getting at least new front shocks as my next big purchase.
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
