Warrior Starter
Old May 3, 2002 | 11:57 PM
Raptor58's Avatar
My Warrior starter just wines when you first hit the button for a few seconds then it will start to turn the motor over but barely. It's not the starter thats the problem because i've tried another starter that i know works and it done the same thing.
Old May 4, 2002 | 12:23 AM
warrior007's Avatar
Could be the relay, but usually you here that from under the left fender making noise at the same time. Really thats the only thing I can think of other than checking all the connections from the battery down to the starter. If you know for sure its not the starter.
On a related note, I found that riva yamaha's microfiche online has part numbers for the brushes to rebuild if needed. Usually yamaha makes you buy the big dollar item to get the $10 part
Old May 4, 2002 | 12:29 AM
Raptor58's Avatar
the starter is actually turn over it just sounds like somthing in the motor is dragging or not engaging
Old May 4, 2002 | 12:40 AM
warrior007's Avatar
well does the rpm of the starter change after the first few seconds as you say? Starters that are bad or arent getting enough current act like what you first described, as they burn any corrosion of connections and the commutator they start to work better again.
If you can tell the starter is wound up all its gonna go and its barely turning over the motor then it could be the starter clutch behind the flywheel. Requires a special puller to get at it.
flyin-lowe
Dec 1, 2017 03:18 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
