Raptor starter, pushing the button twice?
Old May 23, 2002 | 03:49 AM
Mr45auto's Avatar
Just a quick queston on the Raptor. When I start my Raptor, every time hot or cold it requires me to push the button twice. The first time it doesnt do anything but click, the second it starts right up. Is this a starter problem or do I just need to clean out the switch??? It's just wierd.
Old May 23, 2002 | 05:17 AM
RichieRoadRash's Avatar
i can't say for sure, but i've noticed the electric "things" on this quad aren't very good at sealing out crud. i dismantled my lights the other day because one had gone out and it was full of rust and other things. not really any dirt but plenty of rust. i cleaned out the rust and it all came back on. so it may be that. wd-40 is your friend. so check the handlebar switches and the conection to your starter. good luck.
Old May 23, 2002 | 10:26 AM
GreatCanadian's Avatar
Same thing happened on my old Honda 300....the groundwire was loose....maybe that's your problem too....i have no idea where it is grounded on your machine though.
Old May 24, 2002 | 11:43 PM
Turbo33's Avatar
another thing to look at is the box with the fuses on it under the seat.
this goes bad often.
about 12.00 to replace.
Old May 24, 2002 | 11:53 PM
CJM660's Avatar
turbo you never answered what all you have done to those $30,000 raptors
Old May 25, 2002 | 01:53 PM
AlaskaYFM's Avatar
$30000 Raptors?!?! [img]i/expressions/face-icon-small-shocked.gif[/img]
is that like with gold plated frames, custom paint jobs, and a turbo kit???
Old May 28, 2002 | 12:48 PM
Raptorguy's Avatar
Mr45auto,
Check under your seat where positive battery lead attaches on the opposite end from the battery. That rubber block that has a fuse also there has a screw where the positive lead is connected. A couple of months ago my raptor was starting intermittently and it took awhile before I found that the screw had come loose and the lead was only making intermittent contact. Good luck, electrical sucks.
Old May 28, 2002 | 09:52 PM
Smith31's Avatar
I'm having the same problem. Havn't figured out the problem yet(havn't really looked at it either. If I figure it out I'll let u know. I'd appreciat it if u do the same. Thanks a lot
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
JoAnnS
Jul 23, 2015 02:18 PM
Chuck188
Jul 17, 2015 02:45 PM
mudpig79
Jul 13, 2015 03:31 PM
