I get shocked when riding in the rain
I get shocked everytime I read a Mine's faster than yours post.
You will need to start checking all of your connectins.
Is it a shock like from the spark? or is it a constant tingle?
When your getting shocked does the bike run funny like it's missing? If so check your coil to spark plug wires for cracks or cuts.
If it's constant, start checking all of your control connections until you find where the problem is. An Ohm meter might help.
Smitty
Smitty
I assume this problem is on your KE
You are having problems with the kill button on the handlebars. Check to be sure that the hot wire is not rubbing the handlebars and that there are no bare connections that are close to the handlebars. I've seen this on many dirtbikes, as the hot wire is almost touching the bars when it is functioning properly. You can get a new kill switch assembly from your local dealer for about 10 bucks if your's is beyond repair.
Frisky2050
04-09-2020 11:19 AM
