Help with my Elka's
Old Jun 14, 2002 | 10:50 PM
ragingraptor's Avatar
I just installed 19"Elka's w/rezzies and quad rate spring with Houser's long travel a-arms. I've never used an aftermarket susspension but think mine is way to soft. If I stand on the front bumper the shock completely compresses (The top shock body will touch the bumper on the bottom). Is this normal or are they too soft?
Old Jun 14, 2002 | 11:24 PM
swytak's Avatar
You said, " if I stand on the front bumper the shock completely compresses (the top shock body will touch the buper on the bottom)
How is that? Your bumper moves with the frame, shock, motor, etc, etc, etc........Unless you got some kind of crazy stationary bumper, what's the bumper mounted to?
You should notice that your quad is going to sit much lower and will be much softer through the "initial" shock travel. If it is truly bottoming or is extensively soft, by chance did lines going to the shock body or to the res get broke loose. This would cause the shock to loose nitrogen and oil, thus allowing the shock to have 0 pressure other then the springs themselves.
Old Jun 15, 2002 | 12:05 AM
YamaQuad1344's Avatar
He means the bumper on the bottom of the shock shaft, and no they shouldn't be that soft. Are the shocks set up for the longer a-arms? Because if they aren't that will affect the shock's stiffness.
Old Jun 15, 2002 | 12:20 AM
swytak's Avatar
Ah, the shock bumper. Ok makes sense! The shocks must have been broke loose and lost all pressure, even if they were set-up for standard length a-arms.
Old Jun 15, 2002 | 01:50 PM
I'm not really clear but don't know how else to explain it. The shock completly compresses just from my weight standing on the bumper. I know they are supposed to be soft on top but should they be this soft?
Old Jun 15, 2002 | 03:41 PM
swytak's Avatar
No, they shouldn't be that soft. Again, the shock must have come loose and has lost all of it's gas. I would call Elka and explain to them your findings. I am sure they will help correct your problem.
Old Jun 16, 2002 | 10:49 AM
Thanks for checking 3tv. Thats what I was looking for I anyone esle would do the same that has aftermarket suspension that would be great. I don't know anyone with aftermarket suspension to check there machine. I plan on calling Elka monday just looking for some advice on the weekend. Thanx
cboler9
Sep 24, 2015 08:35 PM
86trx250rhonda
Jul 19, 2002 11:13 AM
lonestarbanshee
Apr 29, 2002 02:27 PM
NotuRaptor
Nov 2, 2001 12:12 AM
hyper660r
Jun 26, 2001 08:49 PM
