Warrior Recall , 97 and 98 owners !!!
In the consumer report section of the Minneapolis Star Tribune, it stated Yamaha is recalling ALL 97 Warriors, and certain VIN number 98's,a rear hub problem,something breaking, can cause brake lockup/failure on the rear caliper !!!!! This sounds real serious,so ALL '97's MUST be taken in,I don't have the numbers for the 98's, you should check with your dealer to see if you fall into the recall.
Make sure you have this checked out ASAP !!!!!
Found the phone number to call to see if yours is on the recall list,
it is 1-800-889-2624
