Warrior smoking
Old Aug 12, 2002 | 02:22 PM
preston7's Avatar
I went to the dunes this last weekend and my 2001 warrior puffed blue smoke when it got very hot. Last year I burnt the clutch up and had to replace it. When I changed the oil after changing the clutch, I noticed a lot of debris, probably from the old clutch in the oil filter. I removed the clutch cover and cleaned as much as I could out of the bottom end. This probably has about 100 hours on it.
I am wondering if I need to replace the rings. I am going to test the compression tonight. What should the compression be? Is there a possible problem with the valve seals?
Thanks,
Preston
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
