front sprocket on warrior
Old Mar 19, 2000 | 03:06 PM
fal308's Avatar
I have a 93 warrior. Should I replace the front sprocket with a 13t(original) or go witha 14t? The quad is all stock.
Old Mar 19, 2000 | 07:53 PM
97warrior's Avatar
It depends on the type of riding you do ,and were you do it. If you going hill climbing ,rock crawling,or muddbogging I would go down to a 12tooth,.If your going if sandpits,fields,and clean open fire road type trails then a 14 or even a 15tooth would be good. Now If you plan an doing a littel of each stay stock with the 13,Stock gearing is for general use and usauly makes the best use of the stock engine's powerband. Well hope this helps.
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 27, 2015 07:45 PM
Reactant
Jul 16, 2015 10:29 PM
