92 Blaster no Idle?
Old Aug 24, 2002 | 02:57 AM
BenjaminPQ's Avatar
Having a problem with my Blaster. It won't idle if I turn the down and if I turn it up so it idles it won't some back down from high RPM if i goose the thottle. I replaced the reed seal, carb seal and dry side crank seal. It has been doing this since I bought it anyone know if there is a idle jet to change? Anything I'm missing?
Thanks!
Old Aug 24, 2002 | 03:15 AM
CaptainCarl's Avatar
[1] Only set the idle after it has gotten well into the normal operating tempratures.
[2] Be sure to work the throttle as you are adjusting it. If you don't, then you will always get arratic results.
[3] Is your throttle cable routed correctly, and if so, is it worn out??
[4] Be sure the carb top isn't moving. If it's stripped, it will never idle right.
[5] If all else fails, set the idle as low as you can and then spray carburetor cleaner around the engine and intake manifold. If you have any leaks, the engine will rev up when it sucks in the carb cleaner.
Captain
Old Aug 26, 2002 | 04:18 PM
theyamahakid's Avatar
Listen to Captain. That's exactly what I'd do.
Old Aug 26, 2002 | 04:40 PM
BenjaminPQ's Avatar
Thanks CaptainCarl, I'll give it a try.
franklyme
Oct 21, 2016 07:18 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
