? reed cages
Old Sep 10, 2002 | 12:30 AM
sandblaster15's Avatar
wut do the do? do the give u more power or somethin. would u get more lw end out of them?
Old Sep 10, 2002 | 12:39 AM
how much does it cost change your gear ratio on a blaster?
Old Sep 10, 2002 | 04:31 PM
theyamahakid's Avatar
yeah, they let it breathe better and quicker. if you want to spend the cash, get a rad valve about $120 or you could go for a set of carbon fiber reeds and a reed spacer-$50-$60! I'm fixin' to order the reeds and spacer. i've got almost the same setup as you except mine's a '90 and i've got a uni instead of a K&N- paper is a pain in the a$$!
Old Sep 10, 2002 | 04:34 PM
if you want to change your gear ratio, just change to a different size sprocket!
Old Sep 10, 2002 | 04:35 PM
Peltrax's Avatar
Reed valves allow more gas in and give good power throughtout the revs....It is about 20-40 dollars for sprockets which will change the gearing on a blaster.
Old Sep 10, 2002 | 04:54 PM
Ward660R's Avatar
Will a 250R or 125 mx bike cage work in a Blaster? I have an after market cage in a blaster and I don't know which one it is. I locked at some reeds, the above mentioned, today and they both look similar. Their is no writing on the cage or the reeds. Can somebody help?
Thanks
Old Sep 10, 2002 | 05:35 PM
raptor8's Avatar
get a reed spacer while you're spending bucks. i did notice a difference!
about $30 w/ shipping
Old Sep 10, 2002 | 05:52 PM
Peltrax's Avatar
Most aftermarket builders set up their blaster engines with cr250 reed cages but i dunno what wood fit yours...
Old Sep 11, 2002 | 03:14 AM
Ward660R's Avatar
Thanks that is a start. Its actualy a freinds that I rebuilt. When I put the reeds back in I noticed how bad they were so he went and got some more. The Blaster reeds he came back with don't match the ones in it.
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
