WOLVERINE UVIVERSAL JOINT HELP!
Old Mar 24, 2000 | 08:22 PM
snakeyes93's Avatar
hi,
i have a 97 wolverine. i was wondering if you had any input on my problem dealing with the universal joint connecting to the front differential. (the one closes to the transmission, under plastic cover) the bearings in the cross joint, inside the differential are shot and need to be replaced. now to remove the universal joint i must either A: take off the nut connecting it to the transmission (need esp. thin wrench to get to it) or B: try to push out the end caps of the cross joint, then slipping it out. the problem with answer "B" is that the caps look to be "pressed in with a heavy machine press, could i u think work it loose with time? if you have any comments or other answers please email me at snakeyes93@hotmail.com
thanks alot,
jonathan
nc
Old Mar 25, 2000 | 02:56 AM
thumper4x4's Avatar
You can push the caps out with a good "C" clamp and a couple of sockets
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
