Clutch Question
Old Sep 17, 2002 | 07:19 PM
Ward660R's Avatar
Ok the only difference between aftermarket and stock clutch springs is the tension, right? Could you get the same thing by tightening down on the stock springs? This is assuming they don't break.
Old Sep 17, 2002 | 08:03 PM
RaptorCam's Avatar
If I am not mistaken, aren't the bolts fastening the spring to the clutch assembly equipped with a washer that bottoms out against the pressure plate? If so, then merely tightening the bolts with a higher torque will only push against the pressure plate more. I believe the idea behind replacing with heavier springs is because of the higher spring rate; which pushes the plates, fibers, etc., together with more pressure, allowing the clutch to "hook-up" better. That is how I understand it anyway [img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 17, 2002 | 11:20 PM
Ward660R's Avatar
Maybe I was thinking that they didn't bottom out. Oh well I was just thinking. Thanks
Old Sep 17, 2002 | 11:25 PM
velocityraptor's Avatar
Raptorcam called it right!
Old Sep 18, 2002 | 12:14 AM
JakalWarrior's Avatar
Hey, if your clutch can handle all the tourque at low speed and can overpower the engine but slips at very high speed in high gear what does that mean? new clutch or new springs?
Old Sep 18, 2002 | 01:04 PM
Ward660R's Avatar
Clutch fibers and steels most likely. It happened to me once, on a Warrior, and it ended up just being out of adjustment.
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
