-WARRIOR HELP-
Old Sep 19, 2002 | 09:20 PM
RaceWarrior350's Avatar
sombody tell me what to do here my warrior keeps comin out 3rd gear past 1/4 throttle i took it apart and checked entire trans replace a shift fork but not 3rds it all looks good what else could it be besides tranny. I NEED HELP PLEASE ANWSER ME!!!!
Thanks
Eshelman
88 Warrior
K&N Air Filter
No Airbox
Pro Circuit T-4
Duro Rear Tires
DP Race Brake Pads
Fresh Rebuild
DG Nerfs W/ Red Web
Plastic Redone
99 Blaster
Fatty Gold Series Pipe
Power Core 2 Silencer
Old Sep 19, 2002 | 10:56 PM
JakalWarrior's Avatar
I have 2 ideas, reverse shifter not completely disengaging and the second that it could be the clutch, my shot clutch will just let it rev like crazey when it gets hot and im in a high gear and on the gas. Kinda like waaahhhhhhhhh VVVRROOOOMMM, kinda like it came out of gear but it really didnt. More than likely its the reverse shifter though. The clutch you can kinda tell cause if you get off the gas it comes back.
If its truly your tranny and its kicking out of gear you can hold in the clutch and kinda hear a clacky noise as it tries to fall back in gear. Mine does that every now and then in first and ive had it fall out of high gear too when the reverse lever wasnt perfect.
rockkrawler
Feb 19, 2008 08:50 PM
quadcrasherca
Oct 28, 2005 12:48 AM
warrior68man
Jan 28, 2004 06:46 AM
warrior68man
Jan 3, 2004 11:44 PM
warrior68man
Jan 1, 2004 09:17 PM
