Help With My New Blaster cont.
Old Sep 25, 2002 | 10:51 PM
Kyonic's Avatar
-my original mess
Hi, i am having a problem with my new 2003 blaster. I think it is smoking to much i did not smoke as much as it did now then when i got it. i put 87 gas and 94 and 93 would that have anything to do with it it has Klotz in it. it runs fine idles just right and has the same amount of power. i have had it for 3 weeks now.
-new one
this is what i did i went and bought a new spark plug i took the old or the stock one out, the top was coverered in black normal i guess? then i put the new one in and ran it it smoked the same? and then i took the new one out and it had a brownesh blackesh liquid on it "gas and the oil" so now what do you guys think?
Old Feb 2, 2004 | 10:38 AM
Shav0's Avatar
Default Help With My New Blaster cont.
Your spark plug should be a brown colour, kind of like coffee (double double). If the spark plug is wet and black and the bike is smoking then you have to much oil getting into your engin. Check out what kind of oil is recommended and stick with that. Some of the other oil companys make their oil for injectors not quite right and it ends up being to thin. If the oil is to thin then more will be entering the engin. This explains why the spark plug is so black
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
