Blaster problems
Old Sep 28, 2002 | 04:42 PM
bombrider's Avatar
I have a friend that is interested in buying a used blaster, a 96 one. My question is, is it reliable, and if its not what are its problems????
thanks
Old Sep 28, 2002 | 05:03 PM
dillas23's Avatar
Depends on how hard it was ridden. At the very least I would check the front a-arms, rear axle and swingarm bearings for too much play. Check the brakes, blasters are notorious for brake problems. Check the oil and fluids. Also, check the chain wear and sprockets. If he buys it, he should check the compression and redo the topend.
Old Sep 28, 2002 | 07:47 PM
Pauleo21's Avatar
Ride it, test it out, run through stuff and look at it, my friend had a 97 and didn't have much of a problem at all.
Old Sep 28, 2002 | 10:59 PM
Fez's Avatar
Fez
Blasters dont have problems lol. Take it for a run. A good way to see if he has kept on maintainence is get on it and rock side to side. If you can feel the axle rattle inside the carrier the bearings are shot. If the person is to cheap or lazy to change bearings dont bother buying it its beats.. good luck
Old Sep 29, 2002 | 01:04 AM
YFZRacer's Avatar
mine runs great only problem i had was the TORS once we disconnected that i was good. but ya take it for a ride and see what you thnk
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
