was up to my handle bars in mud and now.....
Old Sep 29, 2002 | 08:50 PM
VirginRider's Avatar
when I try to start my 2002 warior all I get is a clicking noise comeing from the starter relay, is the relay shot? Sometimes when i pick the backend upwards and drop it it starts fine, could the relay just be sticking? Or could there just be something else happening I did try a old relay that I had laying around although I get the same results! I have power the lights work just fine, but If I try to bypass the relay I get no spark at the realy and the engine does not try to turn over!
Old Sep 29, 2002 | 09:28 PM
15 people took a look and not one reply! WOW, come on anything will help!
Old Sep 30, 2002 | 07:39 PM
bump for some helpfull soul! Anything will help.
Old Sep 30, 2002 | 07:42 PM
Ward660R's Avatar
I have had the same thing happen on my Raptor and it has always been a loose connection. Unhook all the electric connections from the bat to the starter and clean the very good. Also look for a short.
Where did the title for this come from?
Old Sep 30, 2002 | 08:21 PM
hardlydangerous's Avatar
Most likely water in the system....pull it all apart (battery connections and electrical connections)clean and dry it all and grease the connections with dielectric grease.
Old Sep 30, 2002 | 09:38 PM
The thing that is really wierd is that when i try to bypass the starter relay I get no spark, and if I try to go directly to the starter I get no spark also! Spark, not meaning at the plug I am talking about spark in general like zap zap.
Old Sep 30, 2002 | 10:08 PM
well knock it off
that zap zap is very hard on the charging system. Power spikes like that will destroy your electrics.
Clean um properly before you really mess things up, start at the battery and work your way down checking all power and grounds.
Old Sep 30, 2002 | 11:05 PM
well I have all the plastic of and all the wire's exposed I have cleaned of all of the grounds, I now have the batterie charging! The thing that really gets me is the fact that the starter will not turn the slightest bit or will not get contact at all with spark seems as if it is dead or if there is no ground for just the starter! Is it possible that the terminal on the starter is not making proper contact inside the starter?
Old Sep 30, 2002 | 11:25 PM
WarriorMadness's Avatar
Sounds like you may have gotten water or mud inside the starter. Pull it off, it comes apart very easily and you can clean it with some contact cleaner. I just rebuilt mine and it works like new now.
Old Sep 30, 2002 | 11:32 PM
hmm that sounds like a plan, this is the best advice I have gotten yet thanks man I really appreiciate it! I will do this tommarro this sounds like it will be a couple hour affair, it is getting kinda late around the new york area!
wendal
Sep 7, 2019 06:46 AM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
