warrior problems please help!
Old Oct 2, 2002 | 01:34 AM
gottarancher's Avatar
Hey guys this is my first post. I am trying to help a friend out with his Warrior. He's been having a few problems. first of all the reverse has never woked. second of all the he used to have trouble getting it started with the electric start. you could push start it every time with no problems after it got warmed up the electric start worked fine. now it won't start at all. the motor seems to turn over okay it just won't start. from what i have been able to figure out all wires seem to be hooked up but there's no fire to the plug. i believe it is a '98. if anyone has any suggestions i would really appreciate your help. Thanks
Old Oct 2, 2002 | 07:08 AM
warrior350megamax's Avatar
Can't help you there with the reverse but with it not starting, check under the nose plastics. Under there should be a little black box (don't know what it's called) and there should be a wire connected to this, if there isn't then you won't get any spark. Good luck,
Patrick
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
