Carillo rod
Old Oct 14, 2002 | 01:58 PM
vilnrk's Avatar
Default Carillo rod
I took some pics to share. Here is what the raptor Carillo Rod looks like. Slowly getting the turbo raptor together again[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 14, 2002 | 04:51 PM
14mins's Avatar
Default Carillo rod
Vilnirk- Do you have any idea is the carrallo rod started life as a Honda civic or toyota product?? Can you list the specs for the rod?? I am just curios if it can be made out of something else like a 100 dollar part. I can't believe that carola makes raptor only. Where did you get the rod?? Thanks
Old Oct 14, 2002 | 07:24 PM
raptorboy673's Avatar
Default Carillo rod
if you are scared to run the rod i will volunteer to test it
Old Oct 14, 2002 | 10:33 PM
vilnrk's Avatar
Default Carillo rod
Hahaha charles, i bet you would.
14mins here are the specs as stated on the card that came with the rod.
P.E. Bore: 0.8672
B.E. Bore: 1.7722
P.E. Thks: 0.866
B.E. Thks: 0.864
weights
total: 444
rotating: 299
reciprocating 145
I'm guesing that these are in grams???
o yea, btw if you buy this rod keep in mind you only get a rod. No pin, no bearings, no shims. nada.
sam coe performance $179.00 bones plus shipping.
Old Oct 15, 2002 | 05:36 PM
AlkyBurninX's Avatar
Default Carillo rod
Does the lower end use a bushing then? 14mins, doesn't the import engines still use a rod cap (two piece rod)? 145 gram rod, pretty light compared to the 800g Oliver pieces in my ford.[img]i/expressions/face-icon-small-smile.gif[/img] Good size pins though. The big end is about the size of the mains in a NASCAR engine if any cares. What length is the rod? JE/SRP makes a few atv pieces and will make ANY custom piston you want (I asked). You can have them make a high pin height so you can have a long rod stroker.
$179 isn't bad if you consider the set of eight for my truck was about $2000.
nitrousoxide
Oct 15, 2005 08:06 PM
JWraptor
Jul 30, 2005 12:52 AM
Chimmer
Sep 12, 2003 11:03 PM
ba01raptoraz
Mar 24, 2003 09:52 AM
Majorecho
Oct 30, 2002 05:21 PM
