WARRIOR ????????????
Old Oct 22, 2002 | 08:32 PM
crankase's Avatar
Default WARRIOR ????????????
What do you do with the wires when you change the clutch perch and block off emergency brake?
Old Oct 22, 2002 | 09:56 PM
JakalWarrior's Avatar
unplug them at the connector and wrap that buddy up in electrical tape.
Old Oct 22, 2002 | 09:57 PM
warrior007's Avatar
Disconnect the parking brake plunger switch down by the steering stem, then tape up the connector. I forget what I did with the clutch safety switch but i think it is the same, watch out it will start in gear.
Old Oct 22, 2002 | 09:58 PM
WarriorManiac's Avatar
Plug the two ends together or it will die when you put it in reverse. Seal her up well.
Old Oct 22, 2002 | 10:08 PM
warrior007's Avatar
Im not sure how I have mine anymore but I do remember it dieing out in reverse before I left it sit and got the raptor, you tie both connectors together??
Old Oct 23, 2002 | 07:54 PM
Just did it myself a little while ago. Best I remember there are 4 wires left unplugged when you remove the factory clutch purch. 2 from the clutch safety switch and 2 from the e-brake switch. I think there is only one female plug from the whole outfit and you plug it up to one of the male plugs from the other set , the green ground best I remember. You're right, it now will engage the starter anytime the little button is pushed. Regardless of the clutch being pulled.
Old Oct 23, 2002 | 08:38 PM
02bansheeman's Avatar
unplug all four by the steering steem and plug two of them together and leave the other two apart no cutting required i dont remember which ones u do what to but from here it aint hard to figure out
Old Oct 24, 2002 | 11:21 AM
alf4444's Avatar
I disconnecet mine all the way to the connectors under the front plastic, didn't plug anything together and i don't have any problems
Old Oct 24, 2002 | 11:36 AM
WarriorMadness's Avatar
I believe my wires are still there, the wires going to the clutch perch are tied together. works great and it will start in gear.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
