Best most expensive two stroke plug?
Old Oct 22, 2002 | 11:16 PM
87Banshee250sx's Avatar
Default Best most expensive two stroke plug?
What is the best, most expensive 2 stroke plug? I need some good ones that wont need replacing in a month to put in my Shee. I know NGK B8Eg's are good. I run B8es's right now,which is the cheapest. But what is the best out there? Bosch? NGK? Champ?
-nick
Old Oct 22, 2002 | 11:26 PM
YFZRacer's Avatar
my dad and me run ngk don't know what kind tho
Old Oct 22, 2002 | 11:28 PM
ben's Avatar
ben
i have b8egv on my lt they are $8.29 a plug,my lt starts faster than my raptor.
Old Oct 22, 2002 | 11:32 PM
KNOWSALOT's Avatar
The Facility
Forget about Champion. Their top of the line plugs are worse than the cheapest of NGK plugs.
The BR8EG is the best plug out there for stock to mildly modded engines. They are the same as the B8EG you are using now except for the resistor feature which is required for most newer dirt bikes have the new CD ignition systems. The "R" plug is also a bit better at preventing fouling although that isn't the intention of the plug manufacturer.
The guys running nitrous and wild engine combinations usually run SplitFire or similar type plug because they burn better than most standard plugs in these conditions, but they offer no performance gain to an engine unless it falls into this category.
Old Oct 22, 2002 | 11:35 PM
Thanks Knowsalot. You are always here to help everyone. Glad u ended up comin back!
-nick
Old Oct 23, 2002 | 12:06 AM
scramblered's Avatar
GO FOR NGK BR9EVX,YOU SHOULDN'T BE DISAPOINTED ABOUT THE SNAP!!!
Old Oct 23, 2002 | 01:12 PM
AlkyBurninX's Avatar
I like the BR9EIX iridium plugs. Just started running them and I am amazed at the burn. Retail is $9.95 each. I also like BR8EG for a cheaper plug.
Old Oct 24, 2002 | 10:33 PM
iamchad2k5's Avatar
i say run 4-stroke plugs....err, hahahaha, they work not great!
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
