Warrior Trans?????????
Old Oct 28, 2002 | 01:07 AM
LOWBOWTIE's Avatar
Default Warrior Trans?????????
[img]i/expressions/face-icon-small-mad.gif[/img]My girlfriend has an 01 warrior. Ive installed a 11:1 piston, 440 web cam,Dyno jet kit,K&N filter and a Big Gun race series exhaust. this thing really rips (for a warrior) This weekend while at sand mountain it started poping out of 2nd gear while pulling hard up the mountain. Ive narrowed it down to if a 200lb person rides it. It will pop out of gear every time but with her on it 105lb it won't pop out of gear. any Ideas? I thought about a new kind of oil (maybe?) but im running Yamalube now. Any help would be great!
Old Oct 28, 2002 | 01:36 AM
Blastermaster's Avatar
A worn out clutch maybe? don`t know just trying to give you a place to start cause i`ve never heard of a warrior having any tranny problems especially an 01
Old Oct 28, 2002 | 10:02 AM
warrior007's Avatar
I had alot of problems like this on hill climbs with my warrior. I am over 200 and it would do it allmost every time. I had alot of slack in my shifter and found I must not have been getting a positive shift. I replaced the shifter with a newer one and I havent had any problems since. Neutral is between 1st and 2nd by just a half click.
If you dont have any slack in the shifter linkage try adjusting the shifter down so the up shift is less movement.
Old Oct 28, 2002 | 11:25 AM
RaceWarrior350's Avatar
Good Friggin luck. I got the same problem except with 3rd gear, i split the cases and wnet thru my trans with a fine tooth comb. i gave up, i bought a bottom end off ebay. I cant figre it out.
EsHe
Old Oct 28, 2002 | 11:34 AM
LOWBOWTIE's Avatar
Thanks Racewarrior, I'll probibly just sell it now ! She wants a new Banshee anyways![img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 28, 2002 | 03:27 PM
JakalWarrior's Avatar
Its the clutch im sure, mine does it too but only when its hot. Im convinced its my oil, but it could be just worn out. Anyone know of a good anti clutch slippin oil?
Old Oct 28, 2002 | 03:33 PM
LOWBOWTIE's Avatar
I thought that same thing until I rode it. It will actually blow the tranny into nutral w/ the clutch pulled in until the RPM slows down. then it slams into first.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
