Which Carb for a 240 Blaster?
Old Nov 7, 2002 | 12:08 PM
1badblaster's Avatar
Default Which Carb for a 240 Blaster?
when my blaster is on gas i run the 35 pwk a.s by kehin and it runs good but i picked .5 of a second in the 300 with the alky carb
Old Nov 7, 2002 | 02:39 PM
Oldmanracing's Avatar
The class rules in Wisconsin do not allow the use of alcohol except open classes.
In that same class you can also run nos and wheelie bars.
This quad is used on fast trails and so is being built around using gas.
Drags have been on a very small scale here. Wish there was more.
Thanks
Old Nov 7, 2002 | 05:52 PM
RC350's Avatar
Oldmanracing:
Yes, we had the boost ports on the intake side. The transfer ports were raised, the exhaust port had been widened and raised significantly as well.
The Keihin PWK Air Striker carbs have "vanes" which help direct air flow over the needle at partial throttle settings. This is supposed to give better throttle response. The standard PWK does not have these additional vanes.
I am not sure if Sudco's website has diagrams of these carbs or not (sudco.com)
I am not sure of the rpm range we were operating in. I suspect it was in the 9,000-9,500 range before power fell off significantly, but don't know for sure. We had planned on dyno-ing the Blaster, but sold it before we got around to it.
Regards,
Rog
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
joeyupton
Jul 14, 2015 11:51 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
