Ultimate Fix for Floor Boards(Grizz Custom Skids)
Old Nov 6, 2002 | 03:21 PM
BigDan's Avatar
Default Ultimate Fix for Floor Boards(Grizz Custom Skids)
First big trip out with my new 03 grizz. Wile on a rock crawling trail I trashed the floorboards. I broke all 8 integrated plastic washers that attached the floorboard to the supports.
First thing I did was, go to the local hardware store and purchased 8 new floor board bolts(same size just longer) and 8 big body type washers. I painted them black and it was better then new.
As for the skid plates it was more complicated. Since I knew this would have to stand up to many years of abuse. I went back down to that hardware store and purchased 8 feet of 1X1 square tube, 20 recessed Phillips head bolts, 1 recessed bolt drill bit, and various nuts and washers. A friend of mine got me the large 3/8” plate of aluminum for Christmas a few years back from an unknown location
I started out by building a new frame/support system off of the original supports. Then I cut the plate to size, and clamped it to the frame I just built. I then drilled 8 or so holes through the plate and frame and attached it with the recessed bolts. I then re-installed the stock floorboards.
Overall it came out great. I only lost ¾” of and inch from the lowest point of the stock floor board to the lowest point on my new Skid plate. I only increased overall weight by 18lbs. If I had used steel instead of Aluminum it would weigh much more.
I would only recommend this set up for rock crawling, since it would be over kill for normal trail riding.
Click Big Dan's Rock Sliders link for pics
Old Nov 8, 2002 | 02:31 AM
BigDan's Avatar
Gimme some feed back guys....
Old Nov 8, 2002 | 11:05 AM
mich660griz's Avatar
i think the floorboards are quite an overkill, until i looked at your sight, lol. the only thing missing on your grizzly now is 4 ft of suspencion travel, lmao!!! i cant beleave them trucks have that much suspencion travel on them. serious stuff. i now have a much better understanding on the upgraded floorboards and skid plates. if your trying to ride it through rocks even close to them on your sight, then a roll cage might be next, lol.
Old Nov 9, 2002 | 09:29 AM
BigDan's Avatar
Too bad they dont make a 4WD Oddessy
Old Nov 9, 2002 | 11:10 AM
mtecate4g's Avatar
I forget what the website was but there was a company that was building grizzlys into oddessys. The lengthend the frame like 6-8 inches put on a roll cage then had a seat in it. It looked like a mini jeep. it only weighed about 800lbs so they didnt add to much weight.
95wolv
Sep 27, 2024 12:00 PM
Oct 10, 2015 10:20 AM
Sep 30, 2015 01:37 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
toonces
Sep 5, 2015 01:14 PM
