Going back from Alcohol, to gas
Old Nov 7, 2002 | 08:51 PM
ryenol's Avatar
Default Going back from Alcohol, to gas
I changed the ole bird back today, due to the cold weather and it being very difficult to get running on the alcohol.(should this be a problem?)
Anyway, now I am wondering if it was a prob with the alcohol, because even on gas, it doesn't seem to want to idle correctly, sometimes sputtering a bit, and then stalling. Before I switched back to gas, it was way to fat(falling hard on it's face at anything above a little over1/2 or 1/3 throttle. Now it won't idle correctly, I have tried adjusting the air/fuel screws, airbox lid, no lid, all to no avail.
Old Nov 7, 2002 | 09:26 PM
sixsixT's Avatar
Sounds like vacuum leak maybe cracked a boot .Would'nt hurt to chech the valves intakes might be tight.
Old Nov 7, 2002 | 11:00 PM
RaceWarrior350's Avatar
sounds like an air leak sumwhere like he said.
EsHe
88 Warrior
Pro Circuit T-4
K&N Filter
Pro Design Intake
Jetted
DG Alloy Nerfs
DP Racing Brake Pads
Duro Hard Terrain Rear Race Tires
Fresh Top End Rebuild
New '98 bottom end
New Plastic
99 Blaster
power core 2 silencer
fatty gold series pipe
Old Nov 7, 2002 | 11:55 PM
KJMAXXX's Avatar
ryenol, how much power did the alcohol add. Was it a big differance.
Old Nov 8, 2002 | 12:14 AM
jiminok's Avatar
...another thread...another topic....found a clue...might be a stretched timing chain causing the erratic idling and poor running...
Old Nov 8, 2002 | 02:50 AM
Ward660R's Avatar
When you switched back did you just put in the same size jet as when it was on gas before. If so it might be to cold for the gas. I don't have to worry about that down here or I might be of more help.
Old Nov 8, 2002 | 12:52 PM
ryenol's Avatar
You know guys, a while back it did move the carbs back. Did not blow them completely off the boots, but damn near. It was running fine then the next day I tried to start it up then problems began, after taking time to look it over closely, I noticed the carbs out of place somewhat. I will have to take the intake boots off and inspect them very closely I guess. I did take the carbs off and completely and thoroughly go through them, and the vaccum boots are in a-1 shape, no cracks of tears there. Well I must state that this is (if it is ) the first major problem with the ole bird....So thanks for all the input.
If this doesn't work, I will then check the valves again(will do that anyway), and then hopefully last check the timing chain..........
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
