blaster smoking
Old Nov 11, 2002 | 12:33 PM
evhwg's Avatar
Default blaster smoking
well my sons blaster decided to start smoking quite a bit and thats with the blockoff on. i took it down the road a couple times and it starts to lose power on high end and smokes pretty bad. i have a feeling this is a crank case seal issue? am i right? how much of a headache am i looking at to change it? and i have been keeping and eye on the oil level and i have to keep adding some evey other ride and i have no leaks.
thanks
Old Nov 11, 2002 | 12:50 PM
Peltrax's Avatar
You might need to rebouild the engine,do you have a way of checking the compression?
Old Nov 11, 2002 | 04:44 PM
theyamahakid's Avatar
yeah- sounds like your top end is pretty much shot. can you hear any rattling coming from the motor at idle. you should probabally hear a kinda sputter noise when you're at a steady spead in mid or top end. Those are all pretty good signs of a shot top end.
-the kid[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 12, 2002 | 10:42 AM
evhwg's Avatar
nope cant be top end. i just had it bored out and .20 over. did that about 2 months ago and it didnt even need it yet. it was still on the original bore.
Old Nov 12, 2002 | 12:16 PM
HotCams's Avatar
Only two things can cause that. 1) The cases have lost their seal where they mate and is allowing oil from the trans into the bottom end. 2) The right crankshaft seal is leaking oil or the nut is loose on the primary drive gear, same result.
Tony
Old Nov 12, 2002 | 12:38 PM
HotCams's Avatar
We should be stocked back up in about 10 days. Sorry.
Tony
Old Nov 12, 2002 | 03:02 PM
kemicalburns's Avatar
is the bike jetted correctly, also what gas mix ratio are you using? Im sure you have already checked this but thought I would ask just incase. after installing the block off plate the mix ration might be different then when it was oil injected you know. just a thought
good luck , hope its not bad.
Old Nov 12, 2002 | 04:24 PM
Peltrax's Avatar
HAy someone settle a bet between me and my brother its stupid but are there cams in pushrod engines??
Old Nov 12, 2002 | 04:30 PM
HotCams's Avatar
Yes, and at least two lobes per cylinder. One for the intake valve(s) and one for the exhaust valve(s).
Tony
Old Nov 12, 2002 | 04:35 PM
Peltrax's Avatar
thanks
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
