banshee
Old Nov 13, 2002 | 07:41 PM
rideraptor420's Avatar
Default banshee
what jet should i be using at 3000 feet and its gettin cold...i have full exhaust and motor work im using a stock filter too
Old Nov 13, 2002 | 10:12 PM
Default banshee
anyone?....the exhaust is popping and spitting and i dont know what to do
Old Nov 13, 2002 | 10:18 PM
pvtCowboy's Avatar
Default banshee
That's not really a good question... the possibilities are endless.. What are you running now? is it too rich? Lean? Is it smooth through the whole powerband? Pull your plug and look at it, that will give you an indication on which way to go. Is it having problems with low temps? If you are not having a problem don't mess with it, you wont make it better...
Old Nov 20, 2002 | 10:44 PM
Default banshee
i pops at low throttle and its running to rich...what is the stock turns out for the air screw.?
Old Nov 20, 2002 | 11:06 PM
ANUFSED's Avatar
Default banshee
The floats might be out of adjustment as well. Try 3 turns out.
Old Nov 20, 2002 | 11:16 PM
Default banshee
thanks man. hey! how much for a k&n for the banshee anyone know?
Old Nov 21, 2002 | 12:16 PM
WyoDuner's Avatar
Default banshee
This if for the Banshee right??? I would think about a 280 main jet, stock pilot should be OK..... Airscrews - well, adjust for best off-idle response. This is assuming a piped Banshee with stock filter.... I don't know what you mean by "motor work". That's the best I can guess with limited info.
Old Nov 21, 2002 | 04:09 PM
Batoutahell's Avatar
Default banshee
I am running either a 280 or 290 at the moment and the air screws are 1.5 turns out. That runs great at about 4500-5000 feet and 60's temp wise.
I would think that you would be in the same range or might try one step higher on the main. You might end up needing slightly higher pilot jets also. I think stock is a 25, might need the 27.5 or 30.
Just guessing, it seems every bike runs slightly different, and of course it depends on mods. I also run the pod filters off the carb. It breathes very well that way.
Bat
Old Nov 21, 2002 | 05:30 PM
800's Avatar
800
Default banshee
I think that main jet it a little small, dont u think?
Old Nov 22, 2002 | 10:57 AM
WyoDuner's Avatar
Default banshee
800, who's main jet is a little small???
