Flat or round slide on carb?
Old Nov 18, 2002 | 04:01 AM
86LTR's Avatar
Default Flat or round slide on carb?
I am looking into getting a new carb for my blaster, and was wondering if you can tell me the differnce between the flat and round style carbs.
thanks
Old Nov 18, 2002 | 07:59 AM
miniblaster's Avatar
i reacently bought a new carb also. I went with the roundside mikuni 28 mm. if your going to eventually do alot more mods you might want to go with the flatside becuse you can upgrade them. This is what i was told when i bought mine. i hope it helps
Old Nov 18, 2002 | 09:21 AM
WarriorManiac's Avatar
86LTR - The major diference in the carbs you mention is the design of the slide. Flat being a newer design the Slide is flat not round as the older designs, hence the names. Flat Slides tout easier tuneability due to needle and jet design, midrange tuning is done with pilot jet and jet needle and E-Clip position. The tout superior throttle response and not as sensative to temperature and atmospheric changes. Mind you I am not and expert these are things I've just read lately since I've been looking at changing carbs also.
Old Nov 18, 2002 | 03:29 PM
AlkyBurninX's Avatar
Flat slide is the way to go. Due to its design, you have greater air velocity with less tubulence because the air hits directly on the slide instead of the sides. The area behind the slide must be curved on a round slide, but can be flat on the flat slide (if you sit them next to each other you can see what I mean). You will make more power and torque with the flat.
slowgsxr97
Mar 18, 2022 03:40 AM
Aitch
Jul 21, 2015 09:40 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Jul 8, 2015 06:13 AM
