Proper mounting of front razorback sand tires.
Old 11-18-2002, 10:40 PM
FISHER1648's Avatar
Default Proper mounting of front razorback sand tires.
I want to ensure that my fronts are mounted properly. Should the straight (flat) edge of the center rib face out with the curved portion facing in ?? I'm guessing this will keep the front tires from washing out in the turns.
Thanks, Eric
Old 11-18-2002, 11:10 PM
THEMOOSE's Avatar
The curved part goes out.
If you turn right the left front does most of the turning because of weight transfer so the cupped side needs to be facing out to get bite.
Old 11-19-2002, 04:03 AM
elsancho's Avatar
you can mount them either way. .. but obviously youll get better turning depending on hoe you do it.. ill try to "draw" a little pictuer of the way to mount them for better turning....
\__ __/ \__ __/
Old 11-19-2002, 04:04 AM
elsancho's Avatar
hmmmm.... the forum software didnt like that... turned it into a picasso
Old 11-19-2002, 04:06 AM
elsancho's Avatar
let me try that again....
\__ __/---------------- \__ __/
ok.. i hope this makes sense
Old 11-19-2002, 08:30 AM
Ward660R's Avatar
It makes sense but is backwards from what MOOSE says.
Old 11-19-2002, 10:28 AM
chad400ex's Avatar
Elsancho has got it right. I've tried them both ways, and for cornering, you want the ribs to be angled outward, which helps keep your front end from "pushing" when turning at high speed.
Old 11-19-2002, 10:38 AM
Ward660R's Avatar
The angle looks like it is on the inside to me, in his drawing.
FISHER1648's Avatar
Elsancho's drawing shows the flat sides out - is this optimum for turning ?
Old 11-19-2002, 01:17 PM
THEMOOSE's Avatar
There reall isn't a straight edge on them. The oppisite side of the cupped side is rounded towards the cup.
Quick Reply: Proper mounting of front razorback sand tires.
