how do I align my front end?
This is from the factory service manual
you alreadt have the caster & camber so all you need is the toe in.
I run mine at 1/8"
ADJUSTING THE TOE-IN
1.Place the machine on a level surface.
2.Measure:
Toe-in
Out of specification →Adjust.
Toe-in:
0 ~ 10 mm (0 ~ 0.39 in)
3 - 43
CHK
ADJ
Toe-in measurement steps:
NOTE:
Before measuring the toe-in, make sure that
the tire pressure is correct.
Mark both front tire tread centers.
Raise the front end of the machine so that
there is no weight on the front tires.
Face the handlebar straight ahead.
Measure the width È between the marks.
Rotate the front tires 180° until the marks are
exactly opposite one another.
Measure the width É between the marks.
Calculate the toe-in using the formula given
below.
If the toe-in is incorrect, adjust it.
Ê Forward
3.Adjust:
Toe-in
WARNING
Be sure that both tie-rods are turned the
same amount. If not, the machine will drift
right or left even though the handlebar is
positioned straight. This may lead to mis-handling
and an accident.
After setting the toe-in to specification, run
the machine slowly for some distance with
both hands lightly holding the handlebar
and check that the handlebar responds cor-rectly.
If not, turn either the right or left tie-rod
within the toe-in specification.
Toe-in = É – È
3 - 44
CHK
ADJ
Adjustment steps:
Mark both tie-rods ends.
This reference point will be needed during
adjustment.
Loosen the locknuts (tie-rod end) 1 of both
tie-rods.
The same number of turns should be given
to both the right and left tie-rods 2 until the
specified toe-in is obtained. This is to keep
the length of the rods the same.
Tighten the rod end locknuts of both tie rods.
NOTE:
Adjust the rod ends so that A and B are equal.
T
R
Locknut (rod end):
15 Nm (1.5 m • kg, 11 ft • lb)
I run mine at 1/8"
2.Measure:
Toe-in
Toe-in:
3 - 43
CHK
ADJ
NOTE:
below.
Ê Forward
3.Adjust:
Toe-in
WARNING
and an accident.
Toe-in = É – È
3 - 44
CHK
ADJ
Adjustment steps:
adjustment.
tie-rods.
NOTE:
T
R
Locknut (rod end):
toe-in for sport bikes
measure the distance between the front tires(at the forfarwd most point) make this same measurment at the rear of the front wheel. Subtract figure a from figure b....BAM toe measurment. with the triple rates measure this with the bike setting on the ground @ ride height.
BRAAAP
BRAAAP
