Whats the story on clutch baskets?
Old Nov 25, 2002 | 09:47 PM
deltadawg's Avatar
Default Whats the story on clutch baskets?
Why is a billet clutch basket better than a stock one? Are the materials different? I notice that Hinson baskets are more expensive than other baskets, I wonder why. Someone shed some light on this. Thank You.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 25, 2002 | 10:32 PM
THEMOOSE's Avatar
Billett aluminum is much stronger, a stock basket is cast & after a while grooves will form on the fingers making the clutch grabby.
Old Nov 25, 2002 | 10:57 PM
fivel250rman's Avatar
I've noticed on a few different raptors there were grooves worn on the inner clutch hub.They were in 3 spots that happens to be right where that metal ring is(that has the 3 teeth that made the grooves)on the inside of the odd friction disk.What is up with that thing?I've heard some aftermarket clutches come with a regular set of plates without the metal ring,probably better without it.
Old Nov 25, 2002 | 10:58 PM
donzilla's Avatar
i am running the hinson in mine because of the strength factor . i blew up a stock unit . the billit can with stand alot more abuse and is just plain stronger .
Old Nov 26, 2002 | 09:55 AM
deltadawg's Avatar
What about the pressure plate? Has anyone had any trouble with it going out. I didnt see too many aftermarket mail order ones offered, but i noticed that GYTR has offered a billet pressure plate? WTF, little knowledge sharing please. Thank you.[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img]
Old Nov 26, 2002 | 10:00 AM
donzilla's Avatar
again the billit pressure plate is stronger and will hold better . they do not make a billit plate or inner hub for the 500 so i sent mine to hinsen and had the hard anodize them for longer life . the gytr is good also . any upgrade will give you more reliability and a better working clutch . hope these posts helped you .
Old Nov 26, 2002 | 07:42 PM
Thanks Airraptor,I'm kicking myself now for not properly identifing the part in question.I should know better.
I still would like to find out why the spring is there.What purpose does it serve?Does anyone know?
Airraptor,the description of your quad is completely sick.I commend you,I've ridden a few with 60hp or less and they are quite a handfull,yours must really haul ***.
Old Nov 27, 2002 | 03:51 PM
Jennifer's Avatar
Just FYI most all aftermarket baskets are made by the same company and then dispersed and stamped with what each individual company wants. This information came from 3 different basket companies I talked to. Big price difference between say a Magnum basket and a Hinson basket.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
